Hello Pierre,
With version XnViewMp 1.3.0 I played with feature FaceTag on my Windows 10 system.
I assigned such a region as shown in attached file FaceTag.jpg.
Then I rotated the image and reopened it.
But to my surprise the rectangle for the region is not where I would expect it.
Yes, XnViewMP tried to set new coordinates for the rectangle;
Best regards
herb
FaceTag and rotation
herb
herb
Re: FaceTag and rotation
Hello Pierre,
in meantime I read the MWG-standard again and came to the following:
- MWG region tags depend ONLY on physical layout of the pixel.
- EXIF:Orientation is not taken into account.
So this means: In case of a rotation done with changing EXIF:Orientation NO change on MWG-region tags has to be performed.
BUT XnViewMP also changes the values in this case.
Best regards
herb
Best regards
herb
Strange, i have many sample files where the MWG region should take EXIF/Orientation
