NITF support not avaialble
anSch
Post by anSch »
Hi all,
I'm currently trying to display NITF files (e.g. the one in the attached archive) containing a simple uncompressed image with a registered and licensed version of XnView.
Hawkstream online viewer is able to decode the image, but XnView does not open the files (neither with ntf nor with nitf file extension).
Are there any configuration options/ plugins that need to be set / installed?
Tested with latest versions of XnView Classic 2.51.1 and XnView MP 1.3.0.
Thanks for your support
Re: NITF support not avaialble
do you have enabled Settings>General>Display all file formats?
