1.3: thumbnail cache lost sometimes after changing folder
fireattack
Post by fireattack »
Unfortunately I don't have a minimum reproducible case, but I always encounter this issue in my use case.
So I have a folder which I used to save my scans (in BMP). I will leave that folder open in XnView MP browser, so I can see all the new images.
After a while, the folder will have batch of images. All with thumbnails already showing, of course.
I sometimes batch rename these files, not sure if it matters.
Now, if I change folder (say, going into a subfolder) and then go back, all the images will somehow re-load its thumbnail.
Please see this example:
This will only happen once for this batch of file. But it will happen again if I scan some new files.
This bug doesn't happen if I just copy and paste files, but it ALWAYS happen if I scan new images.
This is quite annoying, because these files are huge, they took very long to cache.
These are my settings.
Re: 1.3: thumbnail cache lost sometimes after changing folder
no folder in 'excluded'?
fireattack
Nope, that tab is empty.
masterjp
Post by masterjp »
Do you use one instance of XnViewMP or more at the same time?
You can optimize your cache database to get a better performance in thumbnail view.
Try:
Tools menu => settings
=> Catalog => Button Optimize...
Use the following settings:
fireattack
It happens with just one instance. But I do sometimes have multiple opening.
I will try cleanup the db and see if it helps.
Also, I recently noticed that sometimes XnView MP just straight up doesn't refresh the file list. Added a new file in the folder, it didn't show even after refresh (F5). I have to leave the current folder and back to have the new files shown.
waverly
Post by waverly »
fireattack wrote: Wed Oct 19, 2022 5:28 am Also, I recently noticed that sometimes XnView MP just straight up doesn't refresh the file list. Added a new file in the folder, it didn't show even after refresh (F5). I have to leave the current folder and back to have the new files shown.
I experience this bug now as well.
waverly wrote: Thu Nov 24, 2022 7:59 pm I experience this bug now as well.
on all folders?
