.clip files show wrong resolution, for example my files are 3936x2160 and xnviewmp will show them as 1968x1080.
When I open them in clip studio the resolution is correct at 3936x2160.
When I convert files to jpeg using xnviewmp it will output the jpegs at the incorrect resolution, I have to run an action in batch convert to output them at the right resolution.
I am using Clip Studio Paint EX 1.12.3 and XNViewMP 1.3.1 however I have gone back a few versions in both software and it does the same thing.
Thanks!
Tom
Clip studio files show wrong resolution in thumbnail view and preview
tomnel
