Viewing TGA files
SoCu
Viewing TGA files
Post by SoCu »
Hi, do you have to install a plug-in to be able to view a TGA file in XnView MP ?
And with XnShell it is not possible to convert to another format either.
The file in Photoshop looks like this:
And in XnViewMP, it looks like this:
edited
I leave two example TAG files to visualize them.
I have not been able to attach them to the post, because it does not let me because of the size of the file.
https://drive.google.com/file/d/1JaNqr8 ... sp=sharing
https://drive.google.com/file/d/1SjruBk ... sp=sharing
Thanks
SoCu
Re: Viewing TGA files
Post by SoCu »
Hi, I have edited the first post, to put two links of two TGA files, in case someone wants to try.
try to disable 'alpha channel'?
SoCu
Post by SoCu »
Hi, if you mean this option, I have tried checking and unchecking the "Set Alpha channel" option, and the image does not look good either way.
no 'View>Use alpha channel'
SoCu
Post by SoCu »
If, in the window where the image is displayed, you can set "Use alpha channel" (Control + H), and the image looks Good
But they are not displayed in the "Explorer".
And it is also not displayed when you click on the file to open it in full screen,
in [Load] section, you can change useAlpha=false (xnview.ini), and 'View>Rebuild thumbnails' on selected files
SoCu
Post by SoCu »
π•²π–—π–Šπ–†π–™, π–“π–”π–œ π–žπ–”π–š π–ˆπ–†π–“ π–˜π–Šπ–Š π–™π–π–Š π–Žπ–’π–†π–Œπ–Šπ–˜ π–Žπ–“ π–™π–π–Š π–ƒπ–“π–π–Žπ–Šπ–œ π–Šπ–π–•π–‘π–”π–—π–Šπ–—, Β―\_(ツ)_/Β―
πŸ…£πŸ…—πŸ…πŸ…πŸ…š ​ πŸ…¨πŸ…žπŸ…€ ​ πŸ…₯πŸ…”πŸ…‘πŸ…¨ ​ πŸ…œπŸ…€πŸ…’πŸ…—
SoCu
Post by SoCu »
edited
sorry, the file type is not the same, I will create a new post.
