Drag & Drop does not work
pauloadriano
Drag & Drop does not work in the program. Each new version of the program is hanging more and more often.
Re: Drag & Drop does not work
on Windows? Where? Drag&Drop works correctly
TobiGan
Drag&Drop works in an unexpected way: files are copied rather than moved (when dragging from one network folder to another) in the browser
I'm on XnView 1.3.1 on MacOS (MacBook Air M1)
thanks for checking!
