Metadata cannot be saved when converting to JXL
corr
Post by corr »
In the write settings of JXL there are options to keep EXIF, IPTC etc., but they cannot be set.
Or is this dependent on something?
Re: Metadata cannot be saved when converting to JXL
currently metadata are not saved with JXL format
corr
Post by corr »
Can you possibly tell me approximately when that will work?
currently i don't know
corr
Post by corr »
Ok, thank you.
