1.3.1 - BUG - View-Mode - Save as ... doesn't work
PeterNC750
Post by PeterNC750 »
using
XnViewMP: 1.3.1 - 64bit (portable)
OS: Windows 10 - 64bit
- modify a picture in ViewMode (for example: resize or crop)
- trying to save the modified picture with Save As ... (with toolbar-icon / or menue-item File/Save As... / or hitting ESC -> "Save changed file"-dialog appears with button "Save As..." / or pressing Ctrl-Shift-S)
- it is not possible to save the modified picture under a different filename
Using the older version 1.3.0:
all above mentioned possibilities are working well
Re: 1.3.1 - BUG - View-Mode - Save as ... doesn't work
it works here, which output format do you use?
PeterNC750
in
Settings/Formats/Saving
only JPEG/JFIF is selected.
Maybe my words "Save as ... doesn't work" are mistakable.
It's better to say:
the "Save As - dialog window" doesn't appear
A workaround is to select more than 5 formats in Settings>Formats
PeterNC750
thank you very much ...
Very cool workaround :-)
Now it work's ...
This problem is supposed to be fixed in XnView MP 1.4.0. Please check and confirm the bug fix here.
PeterNC750
tested in XnView MP 1.4.0 beta ...
The bug is fixed ... well done ... thanks ...
