XNView - Similar File Matching
dec
Post by dec »
i am trying out the Similar File function of XNView.
it seems very good; but i hv a few queries.
1. there seems to be no Bulk function
2. there seems to be no Autoselect function
(and i have some thousands of images to go through)
3. when you move or delete the last/only similar image, it removes the 'base' image from list (eg so you cannot delete or move it too)
advice?
kindest
Re: XNView - Similar File Matching
dec wrote: Fri Oct 21, 2022 2:55 am 1. there seems to be no Bulk function
What do you means?
yes because there is no more similar items
dec
Post by dec »
dec wrote: ↑Fri Oct 21, 2022 9:55 am
What do you means?
*** the app seems to have no way to 'auto-select' based on various criteris eg size, resolution, date, etc
*** so HOW is "base" image selected?
*** what if i want to delete "base" image, as well as some others?
