Load thumbs from all subfolders
klumy
Post by klumy »
this would be a good addition to the thumbnail options
XNView 1.91.5
Windows XP SP3
Re: Load thumbs from all subfolders
klumy wrote:this would be a good addition to the thumbnail options
Yes, perhaps a good feature...
klumy
Post by klumy »
thanks ;)
XNView 1.91.5
Windows XP SP3
Carefully---
:arrow: Pierre
:) Hello Pierre,
- This could be interesting for image-folders having a lot of sub-directories…
- This binds to create a “flat” display (like "Branch View" in Total Commander); hence, this might be treated very carefully, because whether one clicks accidentally on the root of a big drive, all files of that drive will be called to be displayed as thumb-nails! This could cause a pretty mess, with regard to the necessary amount of needed memory :P
- So, I would support such a feature but it requests well defined limitations; for instance : can't work on the root of a drive…
:mrgreen: Kind regards,
Dreamer
Post by Dreamer »
Support.
Tommy
Post by Tommy »
me too.
Stitscher
Post by Stitscher »
Support ++
Anika
Post by Anika »
It would be helpful if some folders could be excluded with a black list like "thumbs" or "preview". Or if I could restrict it to a searching depth in the directory structure.
XnView 2.04, 2.13 Windows 2000 SP4 and Windows XP SP3 and Windows 7 64bit
JNROB
Post by JNROB »
I agree with all the above suggestions.
There definitely should be a file type and subfolder depth filter.
(to exclude for instance RAW or TIFF or other files)
I also would find useful to be able to toggle on/off title bars for each folder, as in Picajet for example.
Thanks for a great software
