Expanding info pane
scaln
Expanding info pane
Post by scaln »
XnView: XnView MP Windows
Version 1.3.1 64bits (Oct 11 2022)
OS: Windows 10 x64
The info box climbs up on my current layout if I position it underneath the preview pane, have many image tabs open and the window is maximized. After every restart, the info box will climb up upon the preview box and slowly resize the layout.
Effect: Display Glitch
1. Maximize the window
2. Move the info box underneath the preview
3. Open several image tabs, usually about 6-8
4. Restart the program numerous times
Expected behaviour: The layout and info pane should stay the same and not move
Re: Expanding info pane
could you post a screenshot
