"Save as" doesn't work
Merowinger
Post by Merowinger »
Hello!
When I try to save a picture, the "save as" function doesn't work. Nothing happens, it doesn't matter if I use the keyboard shortcuts or the entry in the "File" menu.
System is Windows 10bit, XnView MP Version is 1.3.1.
ReefHound
Re: "Save as" doesn't work
Post by ReefHound »
Is this a JPG? Check tools/Settings/Formats and check Jeff's Image format and JPEG-2000 format.
Please check this post
Merowinger
xnview wrote: Tue Nov 01, 2022 1:22 pm Please check this post
Thank you!
