Canvas Resize in 'MP 1.3.1 /
Gerald_Ire
Post by Gerald_Ire »
Hello my dear XnView'ers :-)
Checking the "Canvas Resize" option for company I found out it takes the content of "ResizePreset.txt" - thats cool :D
Taking one number from "Presets" shows Canvas option "Position" is always "Top left" for the the image. But we need Canvas around with image centered...
When changing this "Position" to "Center" and save it under the same name I'll get a new entry in the Canvas-Presets with same name.
The ResizePreset.txt stays the same... so far so good..
Q.1: where does this new Canvas Preset gets saved? Coudnt find it in xnview.ini..
Q.2: would it be nice to save this in an "CanvasPreset.xml" - maybe?
Not sure if "overwriting the ResizePreset.txt" instead would be pos or any good...
:D Gerald says thx to all! :D
Re: Canvas Resize in 'MP 1.3.1 /
Gerald_Ire wrote: Fri Nov 04, 2022 1:30 pm Q.1: where does this new Canvas Preset gets saved? Coudnt find it in xnview.ini..
Have the same questions )
have not found presets in XnView.dll, maybe there is another sqlite file with settings
Also have few suggestions reagarding file organisation
presets are saved in xnview.ini>presets
Gerald_Ire
hi Pierre, thx for reply ... I'll go on the hunt..
Found 6x presets in xnview.ini...
Will post the result
Gerald_Ire
Found a solution in two steps:
1) "Resize image" to max length (width or heigth -depense on image size) to special px size (sample height 1080 px)
2) use "Canvas Resize" and ad color left & righ or up & below. Sample 1920 x 1080 px
sample: 1920 x 1080 px
Can I do this in one step - only with option "Canvas Resize"?
I think there is an option from "Resize" missing to do so: "Resample / Longest side/Shortest side"
What do you think, is it poss to do this in one step... ?
