I've been using and contributing to XnView for years. I only use the capture feature.
1) When I select part of an image I've captured there's a thin white line that appears across what I've selected and that thin white line is almost always making it so that I can't read the information that's in my capture. Is there someway I can turn that thin white line feature off?
2) XnView used to be able to capture Quicken pop-ups and now it no longer can. If it's possible please make it so the latest version of XnView can capture the Quicken pop-up window.
3) When I click on the 100% button there's a small window that opens up in the bottom right corner of the screen and this almost always is blocking some of the information that I want to see. Is there someway I can disable the small window that pops up?
Many thanks
Emory
"capture" questions
Re: "capture" questions
which thin white line?LongOfTooth wrote: Sun Nov 06, 2022 8:58 pm 1) When I select part of an image I've captured there's a thin white line that appears across what I've selected and that thin white line is almost always making it so that I can't read the information that's in my capture. Is there someway I can turn that thin white line feature off?
you can't capture the popup menu?2) XnView used to be able to capture Quicken pop-ups and now it no longer can. If it's possible please make it so the latest version of XnView can capture the Quicken pop-up window.
Could you post a screenshot?3) When I click on the 100% button there's a small window that opens up in the bottom right corner of the screen and this almost always is blocking some of the information that I want to see. Is there someway I can disable the small window that pops up?
