XnView MP 1.3.1 x64 Portable
OS: Windows 11, win scaling 150%
When opening images in any directory from Explorer or any file manager (for example, Total Commander) and deleting them sequentially (one by one), the last file to be deleted... remains on the screen. Despite the fact that in fact it has already been deleted from the disk and it is no longer in the directory. You have to press the ESC button to close XnViewMP and go back to the file manager. Cache error?
To delete, you can press the DEL button or use the context menu item "Delete ..." - the result is the same. Pressing F5 (refresh) does not help. Exit the program only.
https://thumbsnap.com/FTCEUjz1
https://cdn8.bunkr.is/001_22_11_08-(2)-K1ScEovB.mp4
This happens in both viewing modes - normal and fullscreen. Prerequisite: Images must be opened from Explorer or File manager. Because when viewing files from the application itself (from the browser) there is no such problem.
PS
This bug was still in version 1.0, I did a report about it:
viewtopic.php?f=62&t=43553
But I got an answer to it. It should also be noted that in version 1.3.1 everything has become even worse - now deleting from the context menu does not work either, and F5 does not help.
1.3.1 - Deleting the last file in the folder does not work
Re: 1.3.1 - Deleting the last file in the folder does not work
Thanks a lot, the problem is solved.xnview wrote: Mon Feb 27, 2023 9:58 am This problem is supposed to be fixed in XnView MP 1.4.3. Please check and confirm the bug fix here.
