Hello friends,
I have a new problem in Xnview that just happened all of a sudden without warning. I am on a Mac and for some reason now when I am trying to view thumbnails inside of a folder they will not load. Also when I click on File and then Open if I browse to the directory I can see the images in there but I cannot click on them like they are grayed out.
It is basically useless now as I cannot load images.
Anyone have any tips I can try? I am running Mac OS 13.0.1 and I have uninstalled and reinstalled the latest version of Xnview twice now with the same result.
Thanks so much!
Michael
New problem- Unable to load thumbnails in directory
michaelhames
Re: New problem- Unable to load thumbnails in directory
is it not a privacy problem?? check in MacOS>Privacy
michaelhames
I am still kind of new to Mac so this may have been the problem. I needed to use my computer so I went ahead and did a clean install and everything seems to be working now. It was weird because it was random and out of the blue. Thanks for your tip!
