All files in the folder are not auto updated (need press F5) after deleted or move file on similar files result.
XnView MP ver1.3.1 for Windows
The files in the folder are not updated
Re: The files in the folder are not updated
Describe the steps to reproduce?
alee001
On similar files result dialog, I select and delete a picture is duplicated then close result. The deleted picture alse be shown on folder not refresh?
