1.03.1: clear selection on BW image is shifted
pegas
Post by pegas »
XnView: MP 0.96.4-1.03.1 - 32 bit and 64 bit
OS: Windows 10 - 64bit
Result of the Clear command applied to a selection on black-and-white image is shifted in x- and y-direction.
Effect: image change is different
1. Open some file with black-and-white image.
2. Zoom some part of image.
3. Make rectangular selection by dragging the mouse with the left button pressed.
4. Press key Delete or choose a command Edit/Clear.
Actual behaviour (bug): The rectangle filled by a background color is shifted several pixels in x- and y-direction compared to a selection.
Expected behaviour: The rectangle filled by a background color should be placed at the location of the selection.
pegas
Re: 1.03.1: clear selection on BW image is shifted
Post by pegas »
It seems, that it is the same bug as
viewtopic.php?t=44787
which was fixed in version 1.4.3
https://www.xnview.com/mantisbt/view.php?id=2633
I confirm the issue was fixed.
Thank you!
