A part of the interface uses very small fonts, ignoring Windows 10 scaling, on a 4K monitor.
Is there any way to set the correct font size or fix it?
Some fonts are very small
Azazel
Re: Some fonts are very small
which font scaling do you use? there is some problem with 125, 175
Azazel
150%. I see, so it's not a feature. Ok, I'll return to the Classic version for a while.
