Version 1.3.1 : Batch convert window required to be unusually wide to see full interface
In both the current version of XnView MP 1.3.1, and version of XnConvert 1.96, it seems to be necessary to drag the batch convert window unusually wide in order to see the full interface:
In XnView MP, the Batch convert window cannot be maximised and the Actions window is cropped unless the window is unusually wide:
Widening the window exposes the missing part at the right of the Actions window:
I don't recall that before, have I encountered an unusual combination of circumstances, or has something been changed?
Re: Version 1.3.1 : Batch convert window required to be unusually wide to see full interface
i have not the problem, do you use 'font scaling'?
xnview wrote: Tue Nov 22, 2022 11:37 am i have not the problem, do you use 'font scaling'?
I'm in Linux Mint, whatever my current settings are nothing has changed recently...
I have never seen this before, but possibly when looking in Batch convert > Text action for the drop-down name options at the far right of the Text box, it first became apparent that the window needed to be wider for everything to be displayed?
same thing if you don't have action items?
xnview wrote: Sun Dec 04, 2022 2:09 pm same thing if you don't have action items?
I have since resized the window...
I think the problem probably arose from, in the Text action, having to widen the window further than usual in order to display the drop-down text options list, which I initially couldn't see.
With the program window not set very high, that I think resulted in the unusual window proportions.
Edit:If so, it should be possible to reproduce by opening Batch convert non-maximised, selecting the Text action and ensuring that the window is wide enough to display the text options drop-down, then reducing the window height.
