IPTC Windows Not in Display of Mac
Haze70
Post by Haze70 »
Subject: 1.3.1: <IPTC Windows Not in Display of Mac>
XnView: MP 1.3.1 - 64 bit
OS: Mac 13.0.1/64bit
<The problem is, the IPTC window that opens cannot be made smaller, all the corners are already at their smallest and still it doesn't fit on the screen>
Effect: <display glitch, >
1. <open XN View MP on Mac with M1 Pro 14 Zoll>
2. <open IPTC Window>
correct behaviour of XnView
The second Screen shows the Problem, I can not make it smaller
Re: IPTC Windows Not in Display of Mac
i can't reproduce, in german the dialog is wider but not like yours. You have that even with an image without IPTC?
Haze70
Post by Haze70 »
I have this all the Time when i oben the IPTC Window to Write the IPTC Data
Haze70 wrote: Thu Nov 24, 2022 11:45 am I have this all the Time when i oben the IPTC Window to Write the IPTC Data
if you change to english?
Haze70
Post by Haze70 »
Same Problem in Englisch. First Screenshoot is when I click on the little green Windows that make the Window full-size. after click back, the second Screenshoot shows, that the windows is over the Screensize of my Mac Screen, so a always push the window from the right to the left an the other way around to see all from the open windows
but when you open it without clicking on the green button to maximize it?
Haze70
Post by Haze70 »
It will automatic spring to the false screen Size. What I will do is the picture bigger. So it Spring over the right Size.
It is only on my Mac with the M1 chip. With Intel it works.
All other Windows of XNView will work perfect, I can resize all the no Problems but IPTC Windows still not working
Haze70
Post by Haze70 »
No one have an Idea what I can do or have the same Problem
Haze70 wrote: Mon Nov 28, 2022 4:51 pm No one have an Idea what I can do or have the same Problem
could you send me your xnview.ini?
Haze70
Post by Haze70 »
Mail with the INI File is sent to you.
Haze70 wrote: Tue Nov 29, 2022 5:24 pm Mail with the INI File is sent to you.
i've sent a modified .ini, please try it
Haze70
Post by Haze70 »
So Pierre find the problem, I copy all my files from a other Mac and I works now on my other Mac with the Problem.
This problem is supposed to be fixed in XnView MP 1.4.1. Please check and confirm the bug fix here.
