Increase the size of the Options window
Olivier_G
Post by Olivier_G »
The current Options panel is 579x431 pixels, and looks small on my 21" 1600x1200 display, especially when you consider the amount of settings available...
I suggest we increase it to 640x480, in order to provide more space (especially useful for: Association, Write>File types, Cache, Files displayed...) and overal providing more clarity to the Options, while matching the smaller VGA standard for compatibility.
Olivier
Yes, but---
:) Hello ! Bonsoir,
- Sounds good in the principle, it could be displayed without problem on 1024*768…
¤ It should be useful to get some wider controls, I support.
- However, I fear that users having still 800*600 would grouse a lot ! :P
:mrgreen: KR
Dreamer
Re: Increase the size of the Options window
Post by Dreamer »
Olivier_G wrote:The current Options panel is 579x431 pixels, and looks small on my 21" 1600x1200 display, especially when you consider the amount of settings available...
Olivier
Support.
Olivier_G
Post by Olivier_G »
In 1.82RC1, the Options Window is now larger (642x464). I'm quite satisfied with this change... :).
Thank you, Pierre.
GeorgD
Post by GeorgD »
Seems closed. Related open suggestion: http://newsgroup.xnview.com/viewtopic.php?f=34&t=3744
In the XnView Wiki, you can improve the user guide / documentation / F1-help for XnView (classic/Windows) and for XnViewMP
