Default format when save frame
aticus
Post by aticus »
Hi!
Is it possible to set the default image format when you select "save frame as..." in the video viewer? Now it's always BMP
Thanks a lot!
Re: Default format when save frame
in XnView CLassic?
aticus
Post by aticus »
Hi!
No, with (the wonderful) XnView MP
you was in the wrong forum :)
Currently no, but i'll add an option
i've checked, and you choose the output format
aticus
Post by aticus »
hi! Yes, you can choose the image format but not the default format (so you don't have to choose it every time you save an image). In any case, it is a change that is not important.
Thank you
