1.4.0b1 - draw - transparent figure's backgound visible through border
XnViewMP 1.4.0b1 64bit
Windows10 64bit (22H2), display resolution 3840x2160, win scaling 150%
Draw - rectangle/ellipse
Transparency causes the background of the rectangle/ellipse to bleed through its border.
Expected behaviour
Object's background should not be visible though its border when transparency applied.
ps. looks like this issue has been reported already
0.84b3: Draw tool: Outline overlaps with fill
Related
Re: 1.4.0b1 - draw - transparent figure's backgound visible through border
right i can reproduce
same issue with Text's border effect in Batch convert
not sure that it's a bug. You have same result in Paint.net
it would be fine if there are settings to treat these outer and inner part of the border separately, but thats overkill
also no such quirk in photoshop
