Font bug
xtemp09
Font bug
Post by xtemp09 »
After update to 1.3.1, I can see a font bug involving Tibetan characters.
Here, the font characters displayed shifted. The previous version showed them right (I don't remember the version number).
Windows 10 Pro 20H2 19042.1237
Re: Font bug
I can't reproduce. Could you check which version is working? Do you use windows font scaling?
Re: Font bug
xnview wrote: Sun Dec 04, 2022 2:31 pm I can't reproduce. Could you check which version is working? Do you use windows font scaling?
Previous versions.
xtemp09
Re: Font bug
Post by xtemp09 »
I have downloaded some previous versions, all of them show the filenames as given in the screenshot. Therefore, the problem results from Windows, perhaps, a particular update introduced it. Scaling is off.
In the beginning of the year, I turned off automatic update using some tools, I should have done it much earlier. Ten points to Linux users.
