1.4.0b1 - batch convert - 'Canvas resize' background color and alpha
XnView: MP 1.4.0b1 64bits
OS: Windows 64bit (22H2), display resolution 3840x2160, win scaling 150%
Batch convert
issue A
'Background color' shows selected color, but with Alpha applied (and on black background*) when dialog reopened.
It should show just selected color.
* it is even not a background color from Batch convert settings tab
issue B
Alpha control do nothing to the images without alpha channel
there are few options:
1. disable control for images without alpha channel
2. add checkbox that will enable/disable alpha control, means add/remove alpha channel*
3. keep it always enabled:
-- if value =255 (opacity =1oo%) - DO not add alpha channel to image
-- if value <255 (opacity <1oo%) - ADD alpha channel to background*
* then it will depends on output format's ability to keep alpha channel
as for me, option 2 is the clearest one, 3 is unintuitive
Re: 1.4.0b1 - batch convert - 'Canvas resize' background color and alpha
user0 wrote: Wed Nov 30, 2022 2:17 pm issue A
Right
issue B
I can't disable alpha channel because we don't know if there is 32bits in the file list...
xnview wrote: Sun Dec 04, 2022 2:29 pm I can't disable alpha channel because we don't know if there is 32bits in the file list...
correct, I forgot that we have multiple files in batch )
'Canvas resize' sould not add/delete Alpha channel, only apply some Alpha value to extended canvas space if image already has Alpha
However there is still some 'issue' I would like to address.
Current behaviour, if Alpha channel exists:
  • 'Background color' + 'Alpha' – works as expected (pic 1-3)
  • 'Color of pixel at.'. – does not work as expected
    it applies image's min Alpha value to extended canvas space and there is no way to change it (pic 4, 5)
How to bring more clarity?
  • let 'Alpha' control affect 'Color of pixel at..' as well as 'Background color'
    however some functionality will be lost (ability to apply image's min Alpha value), so maybe..
  • add some selector
    not sure about wording though as all I come up with looks too clunky
issue A
user0 wrote: Sat Dec 10, 2022 8:01 pm
No, it takes color with alpha from selected pixel
fixed in 1.4.3 (by not memorizing Alpha value)
user0 wrote: Tue Feb 28, 2023 6:38 am fixed in 1.4.3 (by not memorizing Alpha value)
fixed in 1.4.4
