B2: Minor: Lossless rotate dialog improvement(s)
Locked
Dreamer
Post by Dreamer »
- remove/rename xnview.ini
- select any jpg image in browser (or view any jpg image in viewer)
- press Ctrl+Shift+R (or +L)
- focus is on 'cancel' button
- press <left> key to switch to 'ok' button
= it doesn't work, you must press <right> button
Also, I think, focus should be only on button(s), not on "[ ] Do not show..." message, because this is used just once and users should enable it by accident.
Re: B2: Minor: Lossless rotate dialog improvement(s)
Dreamer wrote:- remove/rename xnview.ini
Ok
Xyzzy
Post by Xyzzy »
Both problems confirmed in b2 and fixed in b3.
X.
Dreamer
Post by Dreamer »
Xyzzy wrote:Both problems confirmed in b2 and fixed in b3.
X.
Confirmed.
Closed.
Locked
