How to re-store XnView
alee001
Anyone tell me how to re-store or backup setting and database after reinstall Windows and XnView. Thanks.
Re: How to re-store XnView
The most important is to backup/restore your xnview.ini & .db
Re: How to restore XnView
The location of the .ini and the various database files can be found in Tools > Settings... > Integration -- Paths tab.alee001 wrote: Mon Dec 05, 2022 8:20 am Anyone tell me how to restore or backup setting and database after reinstall Windows and XnView. Thanks.
alee001
Thanks, I can found about the files from C:\Users\xxx\AppData\Roaming\XnViewMP , Is there using both backup xnview.ini and Thumb.db only for re-store? or need other files like as registration file to cover?
Do they(*.ini & *.db) include all documented image categories, tags and rating?
you can backup/restore all files herealee001 wrote: Mon Dec 05, 2022 1:08 pm Thanks, I can found about the files from C:\Users\xxx\AppData\Roaming\XnViewMP , Is there using both backup xnview.ini and Thumb.db only for re-store? or need other files like as registration file to cover?
yesDo they(*.ini & *.db) include all documented image categories, tags and rating?
alee001
For many years, such as picture classification, marking, and rating, I am worried that if the picture or folder is changed after reinstalling windows, it will affect the re-store of the backup files?
do you use catalog only? (no embedded metadata)
Files must have same modified date as catalog
alee001
In XnViewMP, I only use categories filter with a rating, people, categories. What mean is no embedded metadata?
If the backup .db file as catalogs and path for D driver, is it only needed to restore/replace .db and .ini after reinstall windows easily?
Settings to store rating/people in embedded metadata (Settings>Metadata)alee001 wrote: Tue Dec 06, 2022 1:32 pm In XnViewMP, I only use categories filter with a rating, people, categories. What mean is no embedded metadata?
yesIf the backup .db file as catalogs and path for D driver, is it only needed to restore/replace .db and .ini after reinstall windows easily?
Helloalee001 wrote: Tue Dec 06, 2022 1:32 pm In XnViewMP, I only use categories filter with a rating, people, categories. What mean is no embedded metadata?
Some explanations about metadata and XnViewMP database here : viewtopic.php?p=179720#p179720
I hope it will help ...
Catalogage avec XnviewMP :
alee001
Thank you for your explanation.
