Files loaded in inverse sort order?
XnConvert seems to load files on the Input tab in reverse numeric order.
To test, download XnConvert 1.96 ZIP version, start XnConvert, and on the Input tab use Add folder to load the extracted attached 'Test files' folder.
The files are displayed in reverse numeric order, rather than the expected numeric order.
Effect: If output files are created using the '#' enumerator, they will be numbered in reverse order.
Test files.zip
Re: Files loaded in inverse sort order?
This problem is supposed to be fixed in XnView MP 1.4.0. Please check and confirm the bug fix here.
