OLE stuff in Delphi
OLE stuff in Delphi
Post by Guest »
Post by Guest »
ole is Object Link Extension (as i remember..) it is "compound file" in short
MAAD
Anonymous wrote:ole is Object Link Extension (as i remember..) it is "compound file" in short
Maad, not quite sure what you mean with your post. Do you want XnView to support OLE? What would be the benefit for the user? (I'm asking because I know OLE just a little bit).
Note: OLE stands for Object Linking and Embedding.
Post by Guest »
this more information how to read/write compound files.. (doc,xls,mic,msi,..)
MAAD
Re: OLE stuff in Delphi
Thanks. Pierre.
