1.4.0b2 - filter - pressing Undo applies current filter
XnView: MP 1.3.1-1.4.0b1 64bits
OS: Windows 64bit (22H2), display resolution 3840x2160, win scaling 150%
Filter
2. open any image
3. open Filter > Filter.. dialog
4. select any filter, e.g. Average, (optional) maximize its settings for better visibility
5. press Undo button
Issue A
filter applies to image
6. press Cancel to close Filter dialog
filter still applied to image
Issue B
7. press left/right to scroll to previous/next file in folder
8. scroll back to initial file
issue caused by Viewer cache and disappears when 'Keep current image' checkbox is unticked (View > Misc > Cache)
Re: 1.4.0b2 - filter - pressing Undo applies current filter
Apply and Undo buttons are always disabled now,
guess it can be counted as fixed :D
