Strange Saving File Progress Bar Behavior
carni
Post by carni »
Subject: 1.3 / 1.4: <Progress Bar Behavior>
XnView: MP 1.3 / 1.4 64 bit
OS: Windows 64bit
The progression bar of the batch-converter is always missing the last image, not showing up as "in progress".
Effect: Confusion, because its not finished even though the bar claims to be finished (Not big deal, just strange)
1. Batch Converting some Files
Actual behaviour (bug): The convert-progress looks like its finished when it clearly isn't. Is this intentional? because it seems not accurate when the intention is to show the actual progress.
Expected behaviour: The end of the progress bar should not be at the end as long
If I single save (Save as.., not batch convert) the image into another file format (avif here) the progression bar is always almost finished, never moving, basically never "progressing". :D
Suggestion: it just says "saving picture..", since avif can take a while, some additional information would be nice to read, like saving from/where to, from/to format, from/to size, from/to px-hight/px-width
It would be nice to not have this "saving message" in the middle of the screen, blocking the whole workplace, reminding, almost warning me that I initiated the saving process like a second ago =)
May be as a top or bottom message, popping up and down when finished
(I would love to upload the example pictures as webp, but the board doesn't allow it :)
Re: Strange Saving File Progress Bar Behavior
