Video error
Joseph1984
Video error
Hi, thanks for this great software, but I have a weird error on the display of any kind of video inside the program, the videos like MP4, avi, webm, etc, are mirrored like the images I add to this message. Is there any way to fix this? Thank you.
Re: Video error
strange on windows 10?
Joseph1984
Re: Video error
Yes, I try installing an old version of the Xnview MP but is the same, since 103.1 I have the problem on all the video files
Re: Video error
Joseph1984
Re: Video error
The error on MP and the sample file https://i.imgur.com/sSQr5fu.mp4
Re: Video error
could you change in you xnview.ini, and send me by PM the content of the debug window
debug=2-
Joseph1984
Re: Video error
there is no fix for this error? Any help with the videos?
Re: Video error
could you try to delete libEGL & libGLESv2 from XnView's folder?
Joseph1984
Re: Video error
No luck, the program freeze and must close it to get again response from it
Joseph1984
Re: Video error
Again sking there is no solve for the problem I have with the videos?
Re: Video error
The author of video component doesn't understand what's happened, you are 2 users with same problem on same card.Joseph1984 wrote: Fri Jan 06, 2023 5:30 pm Again sking there is no solve for the problem I have with the videos?
you can try to disable the internal video component
Joseph1984
Re: Video error
xnview wrote: Sat Jan 07, 2023 8:55 amThe author of video component doesn't understand what's happened, you are 2 users with same problem on same card.Joseph1984 wrote: Fri Jan 06, 2023 5:30 pm Again sking there is no solve for the problem I have with the videos?
Thank you, is there any option on the program to use external codecs or an external video component?
Re: Video error
try editing the xnview.ini
useInternalVideoPlayer=false-
Joseph1984
Re: Video error
Thank you, this partially solves the problem, videos of all kinds can now be seen normally, the only detail is that they are not displayed in a loop, even by checking in the option in the settings section. Any fix for that?xnview wrote: Tue Jan 10, 2023 1:54 pm try editing the xnview.iniCode: Select all
