1.4.0 DEB installation fails [Solved]
I have been unable to install the DEB in Linux Mint 20 Cinnamon, either over whichever version was previously installed, or as a new install.
Earlier versions have installed without any issue, this installation seems to complete normally, but then the application won't open. No error messages.
I regret that I don't have the technical background or the time to investigate myself.
Re: 1.4.0 DEB installation fails
could you try the TGZ package?
xnview wrote: Tue Dec 13, 2022 12:00 pm could you try the TGZ package?
Sorry, I have in the past used several options, and then settled on DEB which has worked very well for me... :D
But I don't have the technical knowledge or time to investigate another format now.
Can someone else who would probably be more knowledgeable reproduce?
Rechecking, /bin has a file xnview installed earlier today, but it can't be launched, the toolbar icon show activity but the program doesn't launch... :(
try to remove styles/libqgtk2style.so, it seems the problem...
Re: 1.4.0 DEB installation fails [Solved]
xnview wrote: Tue Dec 13, 2022 1:46 pm try to remove styles/libqgtk2style.so, it seems the problem...
OK, that was it, I eventually found out how to remove the file by opening the directory directly with elevated privileges... :D
Next time, though, I will follow my usual procedure of waiting a while before installing a new version!
the package is fixed
