1.4.0 - batch convert - default output folder
XnView: MP 1.4.0 64bits
OS: Windows 64bit (22H2), display resolution 3840x2160, win scaling 150%
Batch convert
By default Output settings have blank 'Folder' selected, but all converted files put into the source folder.
So I assume there is UI bug and 'Source folder' shall be selected by default.
Re: 1.4.0 - batch convert - default output folder
right should be 'source folder' by default
issue
This problem is supposed to be fixed in XnView MP 1.4.1. Please check and confirm the bug fix here.
fixed in 1.4.1
