Is it possible to use another or international format for start and end time in the status window in batch conversion?
First you see the day name, month name, day, time hh:mm:ss and then the year.
The informations are a little bit unsorted.
Example: Started at: Tue Dec 13 20:22:11 2022
Is it possible to change it like this: 2022-12-23 - 20:22:11
That is enough. I don't need a day name or month name.
ISO standard for formatting:
https://www.worlddata.info/timezones/da ... tation.php
1.4.0 (and 1.3.1) - batch conversion - status - start and end time
masterjp
masterjp
Re: 1.4.0 (and 1.3.1) - batch conversion - status - start and end time
Thank you!
This problem is supposed to be fixed in XnView MP 1.4.1. Please check and confirm the bug fix here.
