XMP-Metadaten für *.ORF Datei
herb
Post by herb »
Hello Pierre,
I use XnViewMP 1.4.0 on a Windows 10 system.
I used an image that does not contain any XMP-metadata and that has no XMP-sidecar.
After writing XMP-Metadata for a RAW-image (in my case a *.orf image) into the image itself or into the *.xmp sidecar-file
for ALL possible values a tag is created.
I think it is better to write only the not-empty values.
For me it is an error, because in case of a *.jpg file only the not-empty values are written.
Best regards
herb
herb
Re: XMP-Metadaten für *.ORF Datei
Post by herb »
Sorry, but I forgot to say, that I used the dialog Tools --> Metadata --> Edit XMP...
herb
what do you means by 'a tag is created'?
herb
Post by herb »
Hello Pierre,
With right-click on my testfile.orf I selected "Edit XMP...".
The dialog "Edit XMP" showed all fields empty, because the image has no XMP-metadata.
Settings are
- write XMP-metadata into image
- write XMP and update IPTC-IIM
I entered value "Titel" (only this one) and pressed "Write".
This created the following XMP block inside the image:
<x:xmpmeta xmlns:x='adobe:ns:meta/' x:xmptk='Image::ExifTool 12.52'>
<rdf:RDF xmlns:rdf='http://www.w3.org/1999/02/22-rdf-syntax-ns#'>
 <rdf:Description rdf:about=''
  xmlns:Iptc4xmpExt='http://iptc.org/std/Iptc4xmpExt/2008-02-29/'>
  <Iptc4xmpExt:Creator>
   <rdf:Bag>
    <rdf:li rdf:parseType='Resource'/>
   </rdf:Bag>
  </Iptc4xmpExt:Creator>
  <Iptc4xmpExt:Event>
   <rdf:Alt>
    <rdf:li xml:lang='x-default'/>
   </rdf:Alt>
  </Iptc4xmpExt:Event>
  <Iptc4xmpExt:LocationShown>
   <rdf:Bag>
    <rdf:li rdf:parseType='Resource'>
     <Iptc4xmpExt:City/>
     <Iptc4xmpExt:CountryName/>
     <Iptc4xmpExt:ProvinceState/>
    </rdf:li>
   </rdf:Bag>
  </Iptc4xmpExt:LocationShown>
  <Iptc4xmpExt:OrganisationInImageCode>
   <rdf:Bag>
    <rdf:li/>
   </rdf:Bag>
  </Iptc4xmpExt:OrganisationInImageCode>
  <Iptc4xmpExt:OrganisationInImageName>
   <rdf:Bag>
    <rdf:li/>
   </rdf:Bag>
  </Iptc4xmpExt:OrganisationInImageName>
  <Iptc4xmpExt:PersonInImage>
   <rdf:Bag>
    <rdf:li/>
   </rdf:Bag>
  </Iptc4xmpExt:PersonInImage>
 </rdf:Description>
  xmlns:dc='http://purl.org/dc/elements/1.1/'>
  <dc:creator>
   <rdf:Seq>
    <rdf:li/>
   </rdf:Seq>
  </dc:creator>
  <dc:description>
   <rdf:Alt>
   </rdf:Alt>
  </dc:description>
  <dc:rights>
   <rdf:Alt>
   </rdf:Alt>
  </dc:rights>
  <dc:title>
   <rdf:Alt>
    <rdf:li xml:lang='x-default'>Titel</rdf:li>
   </rdf:Alt>
  </dc:title>
 </rdf:Description>
  xmlns:photoshop='http://ns.adobe.com/photoshop/1.0/'>
  <photoshop:AuthorsPosition/>
  <photoshop:CaptionWriter/>
  <photoshop:City/>
  <photoshop:Country/>
  <photoshop:Instructions/>
  <photoshop:State/>
  <photoshop:TransmissionReference/>
 </rdf:Description>
  xmlns:xmp='http://ns.adobe.com/xap/1.0/'>
  <xmp:ModifyDate>2022-12-15T18:00:44</xmp:ModifyDate>
  <xmp:Rating>0</xmp:Rating>
 </rdf:Description>
  xmlns:xmpRights='http://ns.adobe.com/xap/1.0/rights/'>
  <xmpRights:Marked>False</xmpRights:Marked>
  <xmpRights:WebStatement/>
 </rdf:Description>
</rdf:RDF>
</x:xmpmeta>>
You can see that not only tag xmp-dc:title has been created; but this the only with non-empty value.
In addition the file is now "read-only" and a file testimage.orf_original has been created.
Best regards
herb
could you send me the sample file used, i can't reproduce
herb
Post by herb »
Hello Pierre,
thanks for investigations.
I sent the image via mail to contact@...
Best regards
herb
I can't reproduce, could you send me your .ini?
herb
Post by herb »
Hello Pierre,
I repeated the test.
I removed my xnview.ini file and started XnViewMP.
Then I performed the test as described in previous posts of this thread.
The result is identical compared to tests with "old *.ini" file.
What else can be responsible for the described behaviour?
Best regards
herb
ok, i can reproduce when exiftool is users to write XMP. I don't know how to set exiftool to remove empty field.
herb
Post by herb »
Hello Pierre,
Fine that you could also reproduce the problem.
Thanks for your investigations.
To give an answer, we must differ between
- the type of an (ExifTool) tag and
- whether the tag is inside or outside of a structure.
Please share the command you send to ExifTool and I will try to comment.
I hope to have enough experience with ExifTool commands .
Best regards
herb
i use the -j JSON argument, so i can't use -= += operators
herb
Post by herb »
Hello Pierre,
thanks for the info.
Now it is clear to me, why we have so many tags with empty value
(1)
- in case of deleting a tag via json-format you have to use the -f option and value "-" (as described in ExifTool help).
- "-=" or "+=" is only usabel for listtype-tags (as far as I know)
- to add values to a listtype-tag option -j+=<file> is to be used
but this "add-mode" is now valid for all list-type tags
(2)
How do you address elements of a structure-tag.
Do you (a) always write the whole structure or (b) do you use "flattened" tags.
(3)
In case of multiple images selected, you do know only all values of 1 file.
How do you guarantee that values unchanged in GUI keep unchanged in image, when you always write whole structure (a)
(4)
In GUI we have tab "options" with checkboxes
- keep current value in case of no change and
- change only empty values
Why are these option unused in case of only 1 image is selected.
Best regards
herb
herb wrote: Thu Dec 29, 2022 11:54 am - in case of deleting a tag via json-format you have to use the -f option and value "-" (as described in ExifTool help).
-f is not for that, how do you use "-"?
elements like?
yes right, the values will be applied for all selected images.
these options are only useful for multiple images
herb
Post by herb »
Hello Pierre,
thanks for the infos.
(1)
Attached a part of ExifTool help for
-j[[+]=*JSONFILE*] (-json)
Unlike CSV import, empty values are not ignored, and will cause an
empty value to be written if supported by the specific metadata
type. Tags are deleted by using the -f option and setting the tag
value to "-" (or to the MissingTagValue setting if this API option
was used). Importing with -j+=*JSONFILE* causes new values to be
added to existing lists.
(2)
elements like?
Sorry, but I do not understand what you want to ask.
Best regards
herb
herb wrote: Wed Jan 04, 2023 10:56 am -j[[+]=*JSONFILE*] (-json)
yes but i don't understand how to use it
