1.4.3: File not found when using UNC paths
OlGi
Post by OlGi »
Possible de converser en français si c'est plus facile pour vous.
XnView : MP 1.4.0 64bits (Dec 12 2022)
Effect :
There is a bug using UNC paths. Clicking on an image using a path like \\mysrv\sharedfolder\myimage.jpg will display an error message saying "File not found!".
To reproduce :
1. Open File Explorer twith a UNC path (ex: \\mysrv\sharedfolder)
2. Double click on an image
Actual behaviour : Error message saying "File not found!"
Expected behaviour : Open the image in the viewer
Best regards.
Re: File not found when using UNC paths
could you try latest version?
OlGi
Re: 1.4.0: File not found when using UNC paths
Post by OlGi »
I just did right now and edited my post to comply with your bug template. Still the same error. This is really annoying and makes XnView MP useless for UNC paths.
D'avance, merci pour votre aide !
its working here, if you drag&drop the file on XnView's icon?
OlGi
Re: 1.4.3: File not found when using UNC paths
Post by OlGi »
Hi Pierre, I've been investigating deeply and I think I know why this is not working. Sometimes your UNC path has only the DNS name of the fileserver but sometimes it is a FQDN meaning it includes the domain name. I've been playing with paths in different environments and fileservers and NAS and this what I can tell you so far :
UNC path NOT WORKING :
UNC path WORKING :
It seems when a mapped drive is mounted in Windows with the domain name, XnViewMP can't handle the file path correctly.
Additional info, the domain where I have the issue is in the format aaa.bbb.ccc. It contains 2 dots within its name.
You can reproduce this using the command line "net use" to mount a UNC path using your domain name assuming you are in an enterprise environment and not using a workgroup.
It's been also tested with version 1.4.3.
Can you please try to make XnViewMP handle this kind of path please ?
Best regards.
OlGi
Post by OlGi »
xnview wrote: Thu Dec 15, 2022 4:59 pm its working here, if you drag&drop the file on XnView's icon?
Hi, can you confirm you've actually tested on a domain network and not on a workgroup network ? From my point of view, XnViewMP is not handling full qualified domain names correctly on mapped drives.
Thank's for your reply.
Best regards.
