Hide Cursor Not Working in Quick Slideshow
arnold_jordan
Hide Cursor is not working in quick slideshow. I can shove it aside, but this is an irritation. Mac OS 13.1 Thank you very much.
Re: Hide Cursor Not Working in Quick Slideshow
which setting do you have changed?
arnold_jordan
XnView MP MacOSX
Version 1.4.4 64bits (Apr 18 2023)
I have found that the Hide Cursor works in full-screen view mode only after moving the cursor to the top. This pops up the tool bar and thumbnail progress.
After doing that, and drawing the cursor down, the tool bar hides, then the cursor will hide.
I have set: Settings | View | Fullscreen | Hide Mouse Cursor. Also: Fit Image to Window & Floating Views.
Thank you very much!
you means that if mouse stay on 'play bar', the cursor will not be hidden?
