GPS data under Linux with version 1.4.0
bigb262
When I try to display the GPS data with version 1.4 .0, the program crashes! That was not the case with version 1.3x! My operating system is Opensuse Tumbleweed. Hopefully someone can help me here.
Re: GPS data under Linux with version 1.4.0
do you have installed the .deb version?
gueba
I have the same problem with Ubuntu 22.04 and 20.04
XnViewMP 1.4.0 crashes immediately when the "GPS"-Tab is clicked.
This happens with the *.deb , with the AppImage and with the *tar.gz - version.
Error in terminal is shown:
Shall I fill a bug-template? I could send an Ubuntu crash-report, too.
############################################ InfoPropertiesView
Create Tree : Datei
Create Tree : Bild
Create Tree : Kamera
######### CategoryModel :: checkAndSave()
QObject::connect: No such signal GPSMapWidget::reloadMap()
Could not find QtWebEngineProcess
Aborted (core dumped)
Please download again the package, i have fixed itgueba wrote: Sun Dec 25, 2022 12:11 pm I have the same problem with Ubuntu 22.04 and 20.04
gueba
Thank you!Please download again the package, i have fixed it
gueba
There is a new problem:
Clicking a thumbnail shows the red pin on the map. After clicking one more thumbnail, it shows the adjacent pin but the first pin is not deleted. And so on. For every thumb I click, it shows the pin and I can't tell, what thumb it belongs to. I have to restart xnviewmp to get the map cleared off pins.
Very good is, that zooming by mousewheel is now possible.
yes known issuegueba wrote: Thu Dec 29, 2022 2:58 pm There is a new problem:
