XnView MP 1.4.0 64bits
Windows 64bit (22H2), display resolution 3840x2160, win scaling 150%
Viewer
'High zoom quality' + 'Change color depth' few issues that affect only zoomed image, not file itself.
2. open any image AND zoom-out to any value above 100%, e.g. to 200%
3. goto Settings -> View -> View tab
- change 'High zoom quality' to 'Zoom-out & Zoom-in' OR just 'Zoom-out' as there is no isse with 'Zoom-in'
- change filter to anything except default 'Bilinear', e.g. to 'Bicubic'
4. Press OK to save settings
5. open 'Change color depth' dialog AND tick 'Apply to image' checkbox
Issue A
6. change color depth to Greyscale 32.
image will become dark. The problem has the strongest effect at 4, decreasing to 256.
Issue B
6. change color depth to Colors 8
image will shift 1pixel to the top-left corner. Untick/tick 'Apply to image' checkbox to see effect
Related issue:
1.4.0 - viewer - High zoom quality + Change color depth issue
Re: 1.4.0 - viewer - High zoom quality + Change color depth issue
1.5.0b1
A, B fixed
however,
Issue C1
1. set Zoom-in and Zoom-out to Bicubic in Settings
("High Zoom quality" sets on automtically in Viewer's View menu)
2. open test image
3. zoom to 200%
4. goto "Change color depth"
- tick "Apply to image" to see effect
5. set to Greyscale from 4 to 256
image will zoom-in within same canvas size
Issue C2
2. close xnview and open this ^ image
it will be shown cutted from bottom-right at default 100%
it will be shown correctly if:
- press * OR
- switch off "High Zoom quality" in Viewer's View menu (unfortuntely this settin always reverts after restard)
A, B fixed
however,
Issue C1
2. open test image
3. zoom to 200%
Issue C2
- press * OR
how that???
yes another user had this issue. Issue doens't seems to be here when 'Zoom HDPI' is checkedit will be shown cutted from bottom-right at default 100%
variant B
ok so the new issue with 'Zoom on HiDPI' off
all fixed in 1.5.0b2
