I want to use the new feature in 1.40 which allows me to limit sidecar creation to raw files, which is working as intended.
But how do I then hide those xmp files?
If in Browser->File List, I uncheck "Show companion files", the accompanying jpg file is also hidden. This seems to occur whether or not jpg is listed beside {raw} in the " Companion (separated by;)" list.
Companion Files
Franky
Re: Companion Files
If you only want to see the images, you can filter here
Bob_in_MA
Re: Companion Files
Yes, setting custom filters worked... thanks!
