Using classification as filter in 1.4.0
twonky
Post by twonky »
Hi!
I use to classify my pics [1..5] and take e.g. 4 and 5 and do something with them. Just upgraded to 1.4.0, and the classification filter is not in the normal filter anymore. Found it however in category filter.
I have 2 problems I would like to have help with:
1) Problem is that whenever I have selected a classification filter, it seems I cannot go to "no filter" without changing folder (and then back to the folder where Im working. How can I do that?
2) I cannot select "show 3 star or above", i.e. having multiple rating show.
Both of these things were easily accomplished in previous filter menu, but I fail to do it now.
Thanks in advance!
Re: Using classification as filter in 1.4.0
Post by michel038 »
Right, these functions have disappeared from filter menu in the toolbar ... :shock:
An admin should move this post in "MP bug reports" ; if not, one can open a new post there in a few days.
You can use the drop down field at the top of the browser, select the last used folder or any other folder there instead of "DB results"
Gwenael Q.
Post by Gwenael Q. »
The UI has changed :
You will find what you are looking for here : Settings > Browser>Toolbar - Rating. Related post: viewtopic.php?f=62&t=44451&p=182998
Hope this helps
slarti76
Post by slarti76 »
Gwenael Q. wrote: Sun Dec 18, 2022 7:36 pm Hello,
Hope this helps
This is a major step backwards. I constantly need things like "show all unrated pictures", but the new control only let's me select "X+ stars". Gonna have to reinstall 1.3.x...
slarti76 wrote: Mon Dec 26, 2022 9:55 pmThis is a major step backwards. I constantly need things like "show all unrated pictures", but the new control only let's me select "X+ stars". Gonna have to reinstall 1.3.x...
you have the same, click on 'no rating' and <= or =
slarti76
Post by slarti76 »
xnview wrote: Tue Dec 27, 2022 3:37 pm
There's no "<=" or "=". Here's a screenshot, tell me what I'm overlooking:
There's the empty ("0") and 1-5 stars, and when I click on one of them, all pictures with that many stars or more are shown. Perhaps there's something wrong and the relational buttons are not shown?
in default browser mode of clean portable 1.4.0 it looks like this:
slarti76
Post by slarti76 »
user0 wrote: Wed Dec 28, 2022 5:44 am in default browser mode of clean portable 1.4.0 it looks like this:
Ah, I see. I tried clicking the empty space to the left, and it works! So it's merely some display error with the toolbar icons.
Thx for pointing that out and sorry for that.
This problem is supposed to be fixed in XnView MP 1.4.1. Please check and confirm the bug fix here.
