Animated JPEG XL files (or jxl) don't play, only the initial frame is displayed. Example is attached.
The tested version is XnView MP Version 1.4.0 64bits (Dec 13 2022) for macOS 13 (AArch64 Apple Silicon).
Animated JXL not looping only displays initial frame
maci
Re: Animated JXL not looping only displays initial frame
Animated jxl is not yet supported
maci
ok thank you.
