1.4.0 - viewer - copy to clipboard wraps content
XnView MP 1.4.0 64bits
Windows 64bit (22H2), display resolution 3840x2160, win scaling 150%
Viewer
copy to clipboard wraps copied content
2. open any image (e.g. attached test_file)
3. select any part or whole (ctrl+a) image
4. press ctrl+c to copy selection to clipboard
5. press ctrl+q or click X in top-right corner to close xnview
6. run mspaint or any other image prog
7. press ctrl+v to paste image from clipboard
pasted image will be wrapped a little bit from left to right
test image
ckit
Re: 1.4.0 - viewer - copy to clipboard wraps content
Post by ckit »
Confirmed with Paint.NET, PhotoFiltre 11 and MS Paint
This problem is supposed to be fixed in XnView MP 1.4.1. Please check and confirm the bug fix here.
it looks likt this issue has been fixed in 1.4.1
However new bug appears in same conditions - now image colors are messed.
new bug with image paste.png (41.05 KiB) Viewed 1908 times
issue reopened
This problem is supposed to be fixed in XnView MP 1.4.2. Please check and confirm the bug fix here.
fixed in 1.4.2
