XnView MP 1.4.0 - 64 bit
OS: Windows 10 64bit
Although the function is disabled, companion files are displayed.
As it looks, the assignment of the companion files does not work properly. The master extension * has no function at all and if I add another like mkv, it is disabled as soon as a second dot appears in the filename.
In the companion file settings I entered following rules:
* = {ext}.xmp;xmp
mkv = {ext}.xmp;xmp
In my example I have 3 files with companion files:
test2.mkv
test3.x265.mkv
Only the companion file for test2.mkv is hidden.
1.4.0 - Sidecars / companion files are shown
Re: 1.4.0 - Sidecars / companion files are shown
the rule "mkv = {ext}.xmp;xmp" is not needed
This problem is supposed to be fixed in XnView MP 1.4.1. Please check and confirm the bug fix here.
It works fine for me now. The bug is fixed.
