1.4.0 - use filter - 'Focus Peak' does not work on image with alpha channel
XnView MP 1.4.0 64bits
Windows 64bit (22H2), display resolution 3840x2160, win scaling 150%
Use filter
'Focus Peak' does not work on image with alpha channel - image became fully transparent
Re: 1.4.0 - use filter - 'Focus Peak' does not work on image with alpha channel
where do you have focus peak???
xnview wrote: Fri Dec 23, 2022 3:30 pm where do you have focus peak???
Viewer mode
1. open any .png with alpha
2. goto Filter menu (on Toolbar) > Use filter...
3. apply '8. Focus Peak'
image will became transparent
ok, i can reproduce
it depends on the image, filter is applied on alpha channel too
