Scenario
Can't rebuild embedded EXIF Thumbnail for some images which do not have EXIF Thumbnail.
To re-create
1. Execute : Tool->Metadata->EXIF Thumbnail Rebuild.
2. Nothing happens. The image's modify date also doesn't change.
Examples:
https://easyupload.io/0tiquc
(I guess thumbnails of these images were removed to optimize the size.)
I also tested other normal images whose EXIF are removed by XnView(Tool->Metadata->Clean), and things are same.
Expected result
EXIF Thumbnails should be added.
Actual result
They are not changed, and still do not have EXIF Thumbnails.
_______________________________________________________________________________________________
Tech info
• XnView version: v1.3.1 + v1.4.0
• O/S: Windows
Rebuild embedded EXIF Thumbnail - not work
Zipping9519
Re: Rebuild embedded EXIF Thumbnail - not work
yes a known issue if embedded thumbnail doesn't exists
