1.4.0 - Saving AVIF file with YUV 420 setting => saved as YUV444
masterjp
Post by masterjp »
Merry christmas everyone!
I saved a PNG file to avif format with XnviewMP and could not open it with android phones and tablets.
Today I recognized, that XnviewMP saved the avif file with YUV 444, although I selected the YUV 420 format for saving.
Please check it and fix it. Thank you!
Here you can see the EXIF-Infos from the saved file.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Re: 1.4.0 - Saving AVIF file with YUV 420 setting => saved as YUV444
This problem is supposed to be fixed in XnView MP 1.4.1. Please check and confirm the bug fix here.
masterjp
Post by masterjp »
The switch for YUV 420 color format works perfect.
Now it is possible to view images on Android 12 or newer devices.
There is only a problem with picture sizes with odd length or height, but it is a problem of the avif libraries in android 12 or newer!
XnViewMP does not produce the error. Android 12 can not handle picture sizes with odd height or length. :?
I hope they fix it in Android OS.
