I'm using the local folder of Onedrive. The main folder contains about 150 subfolders of roman architectural parts but only a few of them are loaded in each folder (4 images most of the time). In order to fill the folders I have to open images one by one then move them in the right subfolder... but for my current need I have 130 images to load. Is there a way to force XnView to load these image at once?
(You can answer in french if easier :°)
Thanks
Philippe
Loads only a few images for each folder with Onedrive
3dOxyd
Re: Loads only a few images for each folder with Onedrive
do you have this problem only with onedrive folder? the browser shows you only 4 files??
3dOxyd
It appears that NEFs files are no more displayed in some folders. They were, because some folders contain NEFs.
When I click on a folder the whole quantity of files appears briefly then only 4... or 0 are displayed, even if they is no NEFs in the folder.
I updated yesterday but no change. Creating a new folder then moving 51 JPG files in it, only 26 JPG display... but when clicking on another folder and coming back to new folder, info shows briefly 51 files (1/10th of second - down left of the window).
Copying files back and forth in a new folder displays 26 files, then 34 the next time !
BUT:
Copying 102 files from OneDrive to desktop let appear... 102 files... with NEFs !
Let me know if you want other testing.
Regards
Philippe
BUT:
Regards
Philippe
which 'filter by' do you use?
3dOxyd
"images", "tout".
Philippe
Philippe
"When I click on a folder the whole quantity of files appears briefly then only 4... or 0 are displayed", donc la liste des fichiers s'affichent bien puis semble être filtrée. Quel tri avez vous?
3dOxyd
"Images" et "tout" (le "tout" des attributs couleurs).
En effet, cela vient des filtres: j'utilise (je crois depuis toujours) la rubrique par défaut "images"... mais lorsque je mets "tout"... tout s'affiche correctement. Cela signifie que tous les JPG ne sont pas reconnus comme images. Par exemple, je viens d'ouvrir un dossier de 183 images JPG, mais une seule image s'affiche avec le filtre "images". lorsque je passe en "tout" (types d'affichage), tous les JPG s'affichent.
10mn plus tard... j'ai mis le filtre en "tout" et j'ai ouvert une image avec le 'programme associé' (APS). Et là, seule cettze image s'affiche quand je suis en filtre "image". Il faut donc qu'une image ait été ouverte pour être reconnue. Il arrive que toutes les images s'affichent avec le filtre (images), mais lorsque je fais un aller-retour de dossier, j'ai à nouveau une fenêtre vide ou presque. On approche !
3dOxyd
Autre symptôme: je dois ouvrir puis enregistrer une image avec Photoshop pour pouvoir la faire pivoter dans XnView.
Toutes les images ont été faites avec un Nikon D100, D200 ou D800.
Problème solutionné en reconstruisant les vignettes.
C'est bon maintenant?
3dOxyd
C'est bon... mais c'est seulement le problème de la rotation d'images qui a été solutionné
Pour les images qui ne s'affichent pas, c'est bon à condition de comprendre qu'il ne faut pas cocher "images" dans le menus 'filtres' (qui je crois est coché par défaut)... mais cocher "tout".
Autre sujet: à chaque fois que j'ouvre le logiciel, je me demande si j'ai pensé à faire un don; en cherchant un peu j'en ai retrouvé la trace (Avril 20) mais ne serait-il pas souhaitable d'avoir un marqueur dans la fenêtre qui rappellerait si oui ou non un don a été fait?... Ce qui n'empêche pas d'en refaire un autre de temps en temps mais il est bon de connaître la date du précédent.
Merci pour cet excellent outil.
Philippe
Philippe
